12-20-2006 09:24 AM
12-28-2006
03:19 AM
- last edited on
10-05-2025
01:30 PM
by
Content Cleaner
Hi Andrea,
In order to configure your board you have to use Measurement & Automation Explorer ( MAX ).
This tool allows you to set up the board and instruct the drivers about your microphones specifications.
Starting MAX follow these steps:
Right Clik on Data neighborhood>>New Task>>Analog>>Sound Pressure>>select your physical channel for instance ai0 on 4472 >>name the task>>press finish.
You should be able to get quite easily to the configuration panel ( see figure ).
Here you can instruct the board on how your microphone works.
To configure your microphone you must find out the right specifications, important data are about power supply and microphone sensitivity.
If you need you can supply power to your microphone as long as it's IEPE compliant.
You can find more information about this feature and dig further on how work properly your DSA in the 4472 manual.
If you need to transform Pascal values to dB you can use the following formula,
SPL = 20 log10 (p/pref)
where p is the instantaneous sound pressure in Pa and pref is 20 µPa, the internationally accepted reference for sound pressure measurements, which roughly corresponds to the threshold of human hearing.
It's the same suggested by MAX in the rightmost tab.
Hope you can start working easily now.
Best Regards
