Dynamic Signal Acquisition
could anyone give me NI9234 circuitry
Now I want to use NI9234, Does Anyone know the detailed circuitry? I want to learn about whether different channels have the same characteristic when they are connected to different type of sensors.
thanks~~
(6,947 Views)
Here is the manual for the 9234 with an overview of the circuitry:
http://www.ni.com/pdf/manuals/374238c.pdf
In general, the 9234 works with IEPE sensors, and voltage producing sensors where the voltage range is +/- 5volts.  The ADC circuits are separate circuits per channel, so you can independently turn on and off IEPE and AC / DC coupling.
Preston Johnson
Solutions Manager, Industrial IoT: Condition Monitoring and Predictive Analytics
cbt
512 431 2371
preston.johnson@cbtechinc
(6,937 Views)
thank you for your answer. by the way, are the different signal(from different,sampled by ni 9234) still by be filtered in the same way  and in synchronization?
(6,927 Views)
sorry~ from different type of sensors connected with channels of ni9234
(6,926 Views)
