Enhanced Icon Editor
Editing VI Documentation with Icon Editor (for LV12)
With this modified and new VIs, the VI documentation can be edited in a separate tab page in the Icon Editor. I hope this will motivate writing documentation for your VIs.
Known limitations
  • Undo and Redo leave out the documentation elements
    • At least it does this consequently
Installation
  • open the LabVIEW directory "%Program%/National Instruments/LabVIEW 2012/resources/plugins"
  • (optional) backup the original file "lv_icon.lvlibp" by moving it into a new directory ("lv_icon_orig/"):
  • extract the file in the zip file "lv_icon packed *.zip" in the directory
  • The modified Icon Editor should pop up now when you edit a VI in LabVIEW 2012
If this does not work do the Installation for Development (see below)
  • Install the source of the Icon Editor as described here: Icon Editor Source Code for LabVIEW 2012
  • open the LabVIEW directory "%Program%/National Instruments/LabVIEW 2012"
  • (optional) backup the original files by moving this files into a new directory ("lv_icon_orig/"):
    • "lv_icon.vi", "lv_icon.lvproj", "NIIconEditor/Controls/References Cluster.ctl",  "NIIconEditor/Miscellaneous/Menubar/ShowLayersPalette.vi"
  • extract the files in this zip file in the LabVIEW directory ("%Program%/National Instruments/LabVIEW 2012")
    • This wil place some files in "resources/plugins/".
    • only the files mentioned to backup are overwritten
  • The LabVIEW Project containing the Icon Editor VIs is this one: "resources/plugins/lv_icon.lvproj"
Links
Initial discussion and discussing development: Suggestion: Edit Documentation form Icon Editor
Original Idea in LabVIEW Idea Exchange: Icon Editor with VI Documentation
(13,705 Views)
How this looks:
(9,756 Views)
Hey shb,
I am the orignal poster for the idea exchange idea. I am excited someone else is intersted in this. I looked at doing this myself but didn't have any time to work no it currently. I did try downloading you code but it seems like "lv_doc_edit.lvlib" is missing from the zip. I would also like to help you make a compiled version of the icon editor for easier installation.
Let me know when you get that file added to the zip.
Stephen
(9,756 Views)
Right...
The lv_doc_edit.lvlib is included now.
As the best method for distributing I see a VIPM package. But I do not known how to build one which replaces NI VIs. (And undoes this changes when being removed.)
Greetings,
shb
(9,756 Views)
Changes in V2:
Correct tab page is shown or hidden
Instruction for normal installation is corrected,
  packed version for normal installation will follow when I know how to append a 2nd document
changed source files:
added changed file "ShowLayersPalette.vi"
(9,756 Views)
Has this (very useful) idea been incorporated into more recent versions of the Icon Editor?  I notice that there are Source Distributions for Icon Editor 2013, 2014, and 2015 (and, soon, 2016?) -- have these incorporated the Documentation Edit feature?  If not, how difficult would it be to "port forward"?  [I fear to examine the code too closely ...]
Bob Schor
(9,756 Views)
This feature has not been added to any current versions of LabVIEW as of
2015. I do believe this could be added to any of them but I have not tried
recently as we are using a different documentation tool now.
Stephen
(9,756 Views)
