Example Code
FFMPEG scripting in LabVIEW (.NET)
Code and Documents
Overview
"CONVERTING VIDEOS AND AUDIOS HAS NEVER BEEN SO EASY." - And Finally in LabVIEW
How to use "Zeranoe FFmpeg" static 32/64-bit FFmpeg executables with LabVIEW under Windows OS.
FFmpeg examples provided below can be used with any supported sources, i.e DShow devices, network streams, files.
FFmpeg can be used for video analysis and data broadcasting, for more details on how to use FFmpeg refer to https://www.ffmpeg.org/
Description
Attached examples were created in response to question posted at "RTSP over TCP with LabVIEW" thread.
.NET implementation explained:
  • Create process (FFmpeg.exe)
  • Set process parameters
  • Subscribe to process-related Events
  • Use pipes (stdin/pipe0/stdout/pipe1/stderr/pipe2) to move data from FFmpeg to LabVIEW and back
  1. Download and install "Zeranoe FFmpeg" latest static build and place into FFMPEG directory.
  2. Folder snapshot:FFMPEG folder.png
  3. Enjoy FFMPEG scripting with LabVIEW
Requirements to Run
Software
  1. LabVIEW 11.0 or later
  2. "Zeranoe FFmpeg" 32/64-bit static build  -  http://ffmpeg.zeranoe.com/builds/
  3. "RTSP over TCP with LabVIEW" library for RTSP examples - https://decibel.ni.com/content/docs/DOC-35217
Hardware
  1. USB (DShow device) or IP camera or video/audio files
Snippets
***SORRY for broken VI's - LabVIEW's snippet tool backfiring... Files inside zip archive are not broken. I will fix snippets later...***
"FFPLAY - Example - DShow device.vi" - opens user specified DShow device.
"FFMPEG - Example - DShow - stream to file.vi" - Saves DShow device data to mp4 container, user can specify duration or cancel recording at any time.
"FFMPEG - Example - RTSP - stream to file.vi" - Saves RTSP stream to mp4 container, same as above.
"FFMPEG - Example - RTSP-LabVIEW-FFMPEG - stream to file" - Sometimes when FFMPEG fails to establish connection with network device you can relay data with LabVIEW over the pipes (stdin/pipe0 and stdout/pipe1 and stderr/pipe2).
"FFMPEG - Example - RTSP - Extract frame as JPEG.vi" - Extracts single frame from network stream, passes it over pipe to LabVIEW and saves as JPEG file.
"FFMPEG - Example - RTSP - Extract frame as PNG.vi" - Extracts single frame from network stream, passes it over pipe to LabVIEW and draws it.
"FFMPEG - Example - RTSP - Extract frame as PPM.vi" - Extracts single frame, stamps image with timestamp, frame count and duration. Pipes resulting frame to LabVIEW, converts PPM data to 2D Image array.
More examples would come later...
Update 06/29/2015:
"FFMPEG - Example - RTSP - Extract frames (PPM).vi" - FFmpeg processes video stream and passes individual frames to LabVIEW.
Update 07/01/2015:
"FFMPEG Examples v1.1.zip" - updated with "yuv420p" and NI Vision Graph examples.
"FFMPEG - Example - RTSP - Extract frames (yuv420p) Intensity Graph.vi" - yuv420p to 2D RGB
Note: To improve performance, Intensity graph update rate was reduced to 1/5 of frame rate.
"FFMPEG - Example - RTSP - Extract frames (yuv420p) Vision Graph.vi" - yuv420p to NI Vision Graph
Update 12/30/2015:
With script -f sdl "window name" - you can create FFmpeg rendering window (CPU usage is not great but better than what you can do in LabVIEW)
You can specify size, title, background and window title.
FFmpeg sdl documentation
-Artur
Comments
niUser1992
on
Hi GriffinRU
How can I use this development using a video file stored in local, instead of a TCP IP streaming?
Contributors
