FIRST Robotics Competition Discussions
2014 Labview Dashboard source
In the Getting Started Window, create a new dashboard project. That will start out with the source to the default dashboard.
Message 2 of 9
(7,910 Views)
Unforunately that shows Dashboard Main.vi as not being found
Message 3 of 9
(7,910 Views)
Can you browse to the directory that you created that project in and see if it's just named slightly different?
Message 4 of 9
(7,910 Views)
Nope, It seems everything else is there.
Message 5 of 9
(7,910 Views)
I just created a dashboard project from the Getting Started Window and it worked for me.  This is the prefered way to get Dashboard Main.vi.  If that isn't working, you may have a folder set to read-only, or perhaps the source got deleted.
To answer your question, the source of the Dashboard Project (where the wizard copies it from) lives here:
C:\Program Files (x86)\National Instruments\LabVIEW 2013\ProjectTemplates\FRC Templates\Dashboard
Message 6 of 9
(7,910 Views)
Hi Doug,
    All the other files are there except dashboard main.vi.    Before I go and reinstall everything (a process of hours),  only find out it isn't there still (I already did it on 2 computers), can you post it for me?
     Thanks!
         Jack
Message 7 of 9
(7,910 Views)
Accepted by Jackkc7vlo
Hi Jack,
Here is Dashboard Main.vi. I cannot guarantee it will run for you as you could also be missing some other files. You could try to repair the installation rather than uninstall/reinstall by going to the Control Panel>>Add/Remove Software>>National Instruments, selecting the FRC software and choosing repair. This process can sometimes restore missing files from the installation. Please let us know if you have further questions.
Message 8 of 9
(7,910 Views)
Thanks Holly, that's exactly what I needed.
     Jack
Message 9 of 9
(7,910 Views)
