FIRST Robotics Competition Discussions
At the classmate there is 0.0 volt see pic
IS it the Reasons for the 0.0v:
  • The Analog Breakout needs a jumper on the outer two pins
  • The Analog Breakout needs to be receiving power directly from the Power Distribution Panel
(3,639 Views)
Typically all the breakouts require power from the distribution board.  And yes you need the
jumper in order for the battery to be read by channel 8.
(2,756 Views)
