FIRST Robotics Competition Discussions
CRio Ethernet port 2
I have been able to connect to the Axis Camera several times through the Driver station netbook when it is configured to 192.168.0.xx.   I have never been able to communicate the the Camera once I plug into the Ethernet port 2 on the CRio.  When I try to ping the CRio Ethernet port (192.168.0.3, according to reading and MAX) I receive a not available or hardware error.  I have tried many different techniques to access the camera all to no avail.  Are there any sugestions?
Team 2657
Thundercats Ho!
(4,242 Views)
Are you using a crossover ethernet cable when you connect to the cRIO?  I believe that is wha
t you need.  You should have one in your kit.
(2,796 Views)
