FIRST Robotics Competition Discussions
Cammera will not connect to crio
    Subject tells all basiclly when the camera is pluged into the crio the connectivity lights do not light up
Do I have to flash the crio with something?
(5,176 Views)
Are you using an Ethernet crossover cable?
Geoff Schmit
Team 3061
Naperville North High School
Geoff Schmit
Huskie Robotics, FIRST Team 3061 Lead Mentor
http://team3061.org/
@team3061
(3,635 Views)
The camera is connected to ethernet port number two on the crio and the bridge connects to the first ethernet port.
(3,635 Views)
That's good, but what type of Ethernet cable are you using?  If you connect the camera to the cRIO with a standard Ethernet cable the link light won't be illuminated on the cRIO.  You need to connect the camera to the cRIO with a crossover Ethernet cable.
Geoff Schmit
@team3061
(3,635 Views)
Oh ok thats...Didn't realize there was a difference. Now I get it ill see if we can find one.
(3,635 Views)
So a person on our team said he could make one but, on the wikipedia site there diagrams of multi kinds of cross over cables what one exactley do we need?
(3,635 Views)
Hi Jeramy,
Use the 10/100 configuration (the first one in the Wikipedia article).  You should also have an orange crossover cable in the kit.
Good Luck!
Kyle
FIRST Applications Engineer
(3,635 Views)
