FIRST Robotics Competition Discussions
Can not communicate wireless to robot
We installed the new bridge, configured following Labview Tutorial #3.  Everything seem to be accepted per instructions.  Set out lap top to 10.2.223.5 (our team is 223).  Connected bridge to CRIO jack 1, same as last year. Connected our computer ethernet jack to router ether net jack (same router and set up as last year).  Please note: We were operating tether no problem. After booting up CRIO and starting driver station, communications stays red. The robot code is also red...  Router seem to be blinking OK and bridge also had steady blinking light
One thing we did notice, instructions for Bridge had subnet 255.0.0.0 and router subnet is 255.255.255.0, could not change router to 255.0.0.0
Will appreciate any help...  ran out of things to try
Thanx
Mark
(4,391 Views)
Thanx
Mark
just for clarification on your laptop ip... (might be typo but shouldn't it be "10.xx.yy.5" making it "10.2.23.5" ?) I am not sure, but i think this is how it should be setup.
Let me know if this helps.
Davis
(3,435 Views)
This is how I have it set up, 10.2.23.5, it was a typoAny other suggestions?We skip the router this year, set wireless IP to 10.2.23.5ThanxMark
(3,435 Views)
Did you set up the WPA key on the classmate? If the access point was set up with a WPA key then the classmate needs one too. I know for us the WPA key was set to xxxWPAKEY (where xxx was our team number)
"Lockheed" Joe
Testing Blog"
(3,435 Views)
thank you, will confirm again tonight
(3,435 Views)
