FIRST Robotics Competition Discussions
Vision Assistant won't launch on our Classmate (netbook)
Every time we try to launch NI Vision Assistant on our classmate (with or without the Axis cam attached) it gives us an error message that the screens resolution isnt high enough.  Our taskbar is on auto hide and our resolution is set to max, but it still wont launch.  If you know how to bypass this or have another solution, your help would be welcomed.
Team 3620
(3,669 Views)
Hi Team 3620,
Unfortunately you won't be able to use the NI Vision Assistant natively on the classmate. However, if you have one of the new classmates with a VGA port, you may be able to attach a larger monitor to use the Vision Assistant. This hasn't been specifically tested but is worth a try. Otherwise, you'll have to use another computer.
Tanya V
Tanya Visser
LabVIEW Group Manager
(2,867 Views)
