04-09-2015 11:19 AM
I seem to have parts of MAX installed (stuff in the Program Files\National Instruments folder) but there's nothing executable pertaining to it & my start menu search is coming up blank. I've checked another computer with the FRC update, and it didn't seem to have MAX installed either.
04-09-2015 11:32 AM
It'll only install to be executable if you installed either the LabVIEW installation or the NI Vision. If your team is Java or C++ and you're not using Vision, you won't have it. That's why we generally try to avoid using it if possible with FRC conversations.
By chance, do you have another computer you can try this on? I'd like to see if it's isolated to the PC or the roboRIO. We might be able to determine the answer if your team has a second roboRIO as well by trying that roboRIO on the same PC we have the issue on.
04-09-2015 12:48 PM
I've installed the FRC LabView update on another machine. Attempting to flash firmware fails with the same error as before ("There was a problem updating the firmware for this device").
I can't connect to the RIO in MAX (It's not autodetecting the RIO, and manually inputting the IP also fails over USB or Ethernet)
Trying to image the roboRIO from the imaging tool (again, on a 2nd computer, tried from Ethernet and USB) throws the same error.
04-09-2015 01:32 PM
When you're in MAX, do you see it under devices and interfaces, but just the USB interface instead of being able to modify it?
04-09-2015 01:38 PM
Yep!
04-09-2015 02:02 PM
Try going to your device manager in Windows and deleting the device there. Unplug it. Plug it back in and see if the driver associates correctly. Does it appear the same in MAX then?
Also, I sent a private message to you here. I'm not sure how obvious the alerts would be on that.
02-15-2017 11:02 PM
I hava the same problem,can you give me some helps?
