FIRST Robotics Competition Discussions
Classmate not able to program.
I cannot deploy any codes from the Classmate to the CRIO.  i am able to run the codes from my regular laptop
Message 1 of 17
(12,802 Views)
Are you able to see the cRIO-FRC in your project and connect to it on the Classmate?
What is the specific issue you are having that is causing to you not be able to deploy code. By this I mean, what is different than your laptop?
Ben Sisney
FlexRIO V&V Engineer
Message 2 of 17
(4,858 Views)
Yes i see the CRIO and am able to image it, but when i try to run a program, it stops on the waiting for CRIO and will stay that way until i disconnect and close
Message 3 of 17
(4,858 Views)
Are you doing this through your wireless network (Bridge, Router) or with the crossover cable?
Ben Sisney
Message 4 of 17
(4,858 Views)
I am using a crossover cable in case the wireless network was to shut down in the middle of something.
Message 5 of 17
(4,858 Views)
If you have any Firewall/Virus Scanner Software, try disabling those and try again. This includes the windows firewall which may be on by default. Also, verify that your computer's IP address and the cRIO's IP address follow the 10.xx.yy.Z pattern. (Where Z is 2 for the cRIO, etc)
Ben Sisney
Message 6 of 17
(4,858 Views)
my classmate has the firewall off and both the CRIO and Classmate have the correct IP address and is still not working.
Message 7 of 17
(4,858 Views)
Hi Meerick,
Can you post a screenshot of the Deployment Progress window as it's waiting for the cRIO?
Message 8 of 17
(4,858 Views)
Hi Meerick,
If you right click on the cRIO target in your project and select Connect, what happens?
Have you tried power cycling or resetting the cRIO? Are you running the code from the LabVIEW development environment or are you building a startup executable and deploying that?
Are you seeing a dialog box that looks something like this (with your cRIO's name instead of "DisCo-cFP-2220")?
Aaron P
NI FIRST Support
Message 9 of 17
(4,858 Views)
I have tried each of the steps and I keep on getting the dialog box, which stays up until I disconnect. this happens anytime i try to connect or deploy to the cRIO from Labview.
Message 10 of 17
(4,858 Views)
