FIRST Robotics Competition Discussions
Cruch Time Help! 3 LabVIEW Tutorial Videos: State Machines; Faster Code; Simulation
Hello All,
Well, we're down to the last week, and I've been talking to lots of teams. I know many are in great shape, and many are just getting started on their programming.
So, I wanted to squeeze in as much help as I could, as quickly as possible.
Check out the following 3 videos:
1. State Machines: Writing Flexible, Modular Code. Lifter Mechanism Example (http://www.lvmastery.com/TipJar2009-02-08_1)
In this blog entry, I discuss how to use a state machine within LabVIEW to write flexible, modular code. In this example I code and explain the state machine for a mechanical lifting system. much like what many FRC teams may use.
I discuss:
- What state machines are
- How to draw and interpret a basic state diagram
- Creating typedefs for state machine data
- Creating enums to store the actual state
- Storing all sensor inputs and machine outputs in the state machine data for use in debugging and/or the dashboard program
- How to write the state machine code using the case structure, including how to speed up development by duplicating similar cases
2. TipJar #14 - Speeding Up Slow Tele-Op Code and How Parallel Loops Can Communicate (http://www.lvmastery.com/TipJar2009-02-08_2)
In this blog entry, I discuss how to speed up time-critical code by pulling it out of the Tele-Op.vi, while maintaining the ability to share data.
I discuss:
- The fact that there is a lot of stuff going on in TeleOp, and the main loop: can take up to 200ms to run, potentially causing robot damage if limit switches are missed
- How to move the state machine created in TipJar #13 into its own deterministic, accurate, fast loop
- How moving the state machine out of TeleOp causes the debugging dashboard to fail because the state data is no longer available
- How to create a global variable to share the state machine data with the main loop for debugging
- Race conditions: why you should never write to global variables from more than one VI
- How to send info from TeleOp to the parallel loops in an easy, scalable way using a "Command Signal" global
- How using a single command signal can help ensure your important code runs perfectly in TeleOp AND autonomous modes
3. TipJar #15 - Simulating and Testing: How to put your FRC code through its paces on YOUR computer. (http://www.lvmastery.com/TipJar2009-02-08_3)
In this blog entry, I discuss how to simulate your state machine code. The real benefit here is the opportunity to test your logic on your development PC, without needing a functioning robot.
I discuss:
- How to simply modify the previous state machine example for simulation
- How to use a global "Simulate" boolean variable to selectively replace all Hardware inputs and outputs with front panel controls and indicators
- Using case structures to "case out" WPI library calls
- How to watch and debug using execution highlighting, watching the global variables and the front panel
- How you must be sure to simulate all sensors, which includes things like turning off simulated limit switches when the system "moves" away from them
- How to simulate the manual override mode by writing to the "Command Signal" global just like the TeleOp or Autonomous VIs would
__________________
Ben Zimmer
email: ben@enabletc.com
Phone/Fax: (905) 864-1858
Toll Free: (877) 872-4619
Message 1 of 1
(6,309 Views)
