FIRST Robotics Competition Discussions
ERROR-44003 . Need help in resolving it !
Hello there !
                 I tried deploting the basic FRC robot project and I'm getting an error message that states "ERROR- 44003 occurred at camera.lvlib:Issue HTTP Request with Authentication.vi>>camera.lvlib:set Enum Appearance Property.vi>>Camera.lvlib:Set Image Size.vi>>Vision Processing.vi>>Robot Main.vi"
I also get this error after the previous one Watchdog Expiration:System 1,User 1 and whenever I switch from Operations tab to Diagnostics  I get this error with another number i.e Watchdog Expiration:System 4,User 1 and so on..........
(4,916 Views)
This sounds like it might be the same problem described here, at least for the error.  The watchdog is a separate problem.  Is it only the system watchdog that increments?  Do you see that increment if you just leave it on the diagnostics tab for a while?   Is this affecting operation of your robot?
(3,516 Views)
Hi nathan,
                 Its exactly the same problem.I get that watchdog error incremented only if i switch to operations tab and back to diagnostics.But my motors are working fine .I don't think any operation of the robot is interuptted so far ! .
(3,516 Views)
Feel free to let us know if there are any times where you see the robot not function properly and of course we will do our best to assist you.
R&D is currently working on a patch for the Driver Station that will resolve the behavior that you are experiencing.  There should not be any effect on your robot but it will improve connectivity and allow for more meaningful error messages to come through the Driver Station.
I hope this helps!
Thanks!
Bob H
NI FIRST Support
Thanks!
Bob H
(3,516 Views)
