FIRST Robotics Competition Discussions
Issues getting camera to work in dashboard
Since i have reimaged the cRIO a few times, should the ports original settings not be reset as well?
Message 21 of 24
(950 Views)
IT WORKS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! i uninstalled everything and reinstalled all updates one by one in order then reimaged crio created a new basic project, deployed and we are now driving through the school!!!! thanks for all the help everyone, i will still help solve others issues though
Message 22 of 24
(950 Views)
Our only solution has been to reformat the cRIO and go wired to the cRIO.  Our wireless bridge has gone AWOL.  When we are wired to the cRIO everything works fine.  I'm going to try to replace our game adapter as it is clearly too buggy to work.
Message 23 of 24
(950 Views)
make sure there is nothing between the gaming adapter and the router that could cause issues with connecting, while we we're driving around the school we noticed that the communication was a bit fuzzy when we left the router in the classroom. I'm assuming it's due to the fact that we we're going 3 brick walls, anything between the two will be enough to reduce the signal though it's a matter of how much a material will reduce it by
Message 24 of 24
(950 Views)
