FIRST Robotics Competition Discussions
Labview FRC USB Camera Programming
I have looked everywhere I could find on how to do this. On our roboRio, I have plugged in a USB logitech webcam. I have then plugged an ethernet cable from our roboRio to our OM5P-AN router, and then an ethernet cable from the router into our laptop. When I open the driver station and enable our robot, I get a live feed from the camera, and the robot drives. When I disconnect the  ethernet cable from our laptop, the robot drives but we lose the signal from our camera. So how do I make the USB camera stream a live feed to our driver station without being connected via ethernet cable? I have no experience with vision assistant or anything other than labview. I have looked around online and I just cannot figure it out. If anyone could help us out it would be fantastic.
(5,113 Views)
Can you post your vision code or an image of you Vison Processing.vi? Did you try to set the input of the camera open to USB 0
digging into the Vis I see that the only option for names of USB cameras
are
USB 0, USB 1, USB 2, USB 3 (must be these names exactly Cap USB space #)
Mark
Champion CLA
Making senseless computers do
intelligent real world things
is NOT easy. SO MAKE IT FUN!
(5,040 Views)
