FIRST Robotics Competition Discussions
Labview Robot Main Enable Vision Button
I am having trouble getting live feed from my usb camera without it being tethered. I noticed that there is a button in Robot Main labeled "Enable Vision". When I click on this, it lights up green. But when I save it and reopen, it is turned back off. How do I keep this button on so I can recieve live footage from my usb camera in the driver station?
(4,189 Views)
if you want the button to default as true follow these steps
  1. Click on the button and set it to true
  2. Then right click on the button and select Data Operations>>Make Current Value Default
  3. Finally Select File>>Save All to save the changes
Now the vision loop will transmit images to the dashboard everytime you run the Main.
Champion CLA
Making senseless computers do
intelligent real world things
is NOT easy. SO MAKE IT FUN!
(4,139 Views)
