FIRST Robotics Competition Discussions
Licensing/Activation for FRC LabVIEW 2013
Hey guys,
My laptop recently died at a competition, so I've been trying to setup FRC LabVIEW 2013 and the rest of the utilities on a new Win7 64-bit laptop. Unfortunately, I cannot activate my LabVIEW products for some reason, using the NI License Manager - so I'm running in Evaluation Mode, and robot code will not build/compile so I can run it as startup code (because certain modules, such as the PID and Fuzzy Logic one, are running in evaluation mode and cannot build in that mode for some reason). I understand my serial number (on the FRC LabVIEW DVD sleeve) to be M77X12313, and the activation code for FRC LabVIEW to be S14X86768.
Can anyone help me out? I called (888) 280-7645 and they said to come to these forums.
(14,804 Views)
You should be able to activate with just the serial number, which is actually the : S14X86768. number
Kevin Fort
Principal Software Engineer
NI
(6,004 Views)
thank you...
(6,004 Views)
thanks a lot
(6,004 Views)
