FIRST Robotics Competition Discussions
New TipJar Video: Everything So Far - A Guided Tour of Our Team's LabVIEW FRC Code
Hi Everyone,
I've posted a new TipJar video, giving a summary of the TipJar Videos so far, as a tour of Team 843's FRC code.
http://www.lvmastery.com/TipJar2009-07-02
The purpose of this video is not to teach new concepts, but to relate back to ones taught in previous Tip Jars.
I discuss:
* The concept of robustness: good code can be easily modified, debugged, scaled to work in different situations.
* The Block Diagram, Begin VI, TeleOp VI, Lifter VI, Steering VI, Debugging VI, and Autonomous Independent.
* The uses of the “Command Signal”: initializing it, writing to it, and reading from it.
* The use of “Boolean trigger” to have actions take press on joystick button presses only when pressed or released.
* A consistent and robust approach for programming a robot function VI using a "shifter".
* How to create and use “Re-entrant VIs” to modularize and reuse code for identical robot subsystems in parallel.
* How to use the command signal architecture to create a simple autonomous VI which uses the full functionality of your robot code.
All the best,
Ben
__________________
Ben Zimmer, Enable Training and Consulting
email: ben@enabletc.com
Phone/Fax: (905) 864-1858
Toll Free: (877) 872-4619
Message 1 of 1
(3,935 Views)
