FIRST Robotics Competition Discussions
Setting up the d-link problems
We finaly got a new d-link and when I follow the instructions on the tutorial, instead of getting to the setp page it says "internet explorer cannot display this webpage"
(5,132 Views)
It also says "the address is not valid"
(3,751 Views)
Accepted by reaper559666
If you hold the reset button on the router it will reset it to the factory deafult IP (on the bottom of the router). Set your computers NIC to have an IP in the same subnet. You should then be able to connect to it and reconfigure it to the desired IP range.
Kevin Fort
Principal Software Engineer
NI
(3,751 Views)
