FIRST Robotics Competition Discussions
So uhh... Tank Drive? Arcade Drive?
I am very new to FRC, and to programming, so I don't know a lot of things, so what is the difference between tank drive and arcade drive?
(7,891 Views)
Arcade drive uses a single joystick and moves the robot in the direction that you "point" with the joystick.  For example, to move forward, you push the joystick forward; to turn right, push the joystick to the right; etc.
Tank drive uses two joysticks where the left joystick controls the speed and direction of the left "tread" and the other joystick controls the speed and direction of the right "tread".  To move forward, you push both joysticks forward; to turn right, you push the left joystick forward and the right joystick backward.  Some large lawnmowers are operated with a tank drive-style control.
Hope this helps...
geoff
Geoff Schmit
Team 3061
Naperville North High School
Geoff Schmit
Huskie Robotics, FIRST Team 3061 Lead Mentor
http://team3061.org/
@team3061
(4,117 Views)
(4,117 Views)
