FIRST Robotics Competition Discussions
a burning question on making a ramp with scan features
I wanted to make a rate-tunable ramp signal which can be fed to the elec-device via analog output of DAQ board. I tried a simple one, and it seems working. Ramp starts from the set values and stops when it reaches the max set, this is all right, but how can I make it automatically initialize itself and starts over again for the same range? any help would be really appreciated!!!
Regards
(3,601 Views)
Is this example related to FIRST Robotics?  I noticed that you are not using anything specific to FRC or FTC.  If you just have a LabVIEW Question please repost it on the LabVIEW Discussion Forums.  There are more community members that keep an eye on that forum and will be able to assist you better.
If there is anything else that I can do for you please just let me know.
Thanks!
Bob
NI FIRST Support
Thanks!
Bob H
(2,838 Views)
