FIRST Robotics Competition Discussions
query
I have got something like 10 push buttons in my program where initially I have to set either true or false value from loading from the configuration file. Once I load from the config file and the initial settings are done then I will use the control of push button. Basically I need 2 set the initial settings by loading from configuration/text file.
(4,191 Views)
It sounds like you are trying to set the default value of a control.  There are a couple of ways to do this.  First, you can right-click on the control and select "Data Operations-->Make Current Value Default".  Another option is to use the Value property node.
I do have a question about the configuration file that you are talking about.  What are you trying to accomplish with this?  How are you trying to use it?
Brandon T.
(3,420 Views)
