FIRST Tech Challenge Discussions
How do I "Force" a reinstall of the FTC Toolkit? (Archived)
Update: This discussion applies to Issues from the 2010 FTC season and is no longer relevant for current FTC competition software.
I've read the various instalation docs but can't seem to figure this one out.
I want to ensure that I'm using the latest templates for development, but I've had a lot of different files in these folders over the last two years.
I figured that I'd wipe (rename) the examples/FTC_Toolkit folder and just re-install the latest FTC update.
Unfortunately the installer says it's not going to do anything since the update has already been installed.
What can I un-install/delete to force the update to run and give me clean copies of the FTC examples?
Phil.
Get a life? This IS my life!
(4,050 Views)
Phil,
I can check with our installer developers to find out what you will need to do in order to completely remove the FTC Toolkit from your computer.  Please be aware the new FTC Toolkit (f3) for this season will install on top of the old toolkit without issue.  I have also posted the default templates and templates implementations.
Mark
NI App Software R&D
(3,021 Views)
Thanks.
Being able to get clean copies of the templates/implementations will do the job.
Phil.
(3,021 Views)
