FIRST Tech Challenge Discussions
Need help with code (Archived)
Update: This discussion applies to Issues from the 2010 FTC season and is no longer relevant for current FTC competition software.
We have been using the new FTC code and keep having a problem with the following code.  We are trying to run the motors on the wheels on one joystick in arcade mode.  We are trying to run two other motors (seperate motors) on other joystick.  However we can only get the motor controls for the wheels to work.  Neither of the other motors will function.   We need some help to determine what in our code is wrong and how to fix the problems.  It would be helpful if someone had some VI that had at least two seperate motors  doing different things to see it that would help.  Thanks for the help.
(4,325 Views)
See my recent answer to your previous post here:  http://decibel.ni.com/content/thread/8399?tstart=0
Get a life? This IS my life!
(3,194 Views)
