FOUNDATION Fieldbus
I HAVE PROBLEMS WITH THE COMUNICATION IN THE NI-8486
I've attached a photo of my powerhub. Connected are H1 devices, one of them being USB-8486.
Message 11 of 17
(7,857 Views)
look at these pictures i showed you how i plugged my power hub device and then i run the program and it showed me an error in activation code i think it was another kind of problem but when i am asking for a new code i received a message with this:
Dear Customer,
We apologize for any inconvenience; however, the submitted serial number does not require activation. This product can be used without an activation code.
Please see below links for more information:
http://www.ni.com/license/product_activation.htm
http://www.ni.com/activate
http://www.ni.com/license/activation_faq.htm
National Instruments Services Programs
----- Forwarded by National Instruments - Customer Services [TMD] -----
Heleodoro Cordova Jauregui
<heleodoro.cordova@coimsur.com.mx>
To:
<activate@ni.com>
Cc:
Date:
2014-03-31 10:28:27.0
Subject:
RV: Enviando por correo electrónico: NIProductsLicenseForm
so i will show you all the files i have until today.
Message 12 of 17
(7,842 Views)
these are other files
Message 13 of 17
(7,841 Views)
these are other files the second part or maybe the third
Message 14 of 17
(7,840 Views)
Hi JAUREGUI_HELIO,
With the photos, I can only assume you've connected USB-8486 to the powerhub (KLD2-pc-1.1) correctly, if the black wire connected to the 123 456 side on the lower port is USB-8486. If so, there should be no problem.
The reason you've got the email response saying you do not need activation is most likely because you've only purchased the USB-8486 hardware. It could be intended so because NI-FBUS Communication Manager is free for use, using which you can develop application using the API provided (C, VB, .NET, and VI), thus you do not need to activation NI-FBUS Configurator or Monitor which are paid software.
You can give me your serial number for me to check whether your have purchased NI-FBUS Configurator and/or Monitor in your order's configuration.
Message 15 of 17
(7,835 Views)
ok the Serial Number: 15AFF72 i would like that you help me.
Message 16 of 17
(7,822 Views)
15AFF72 (with software SN H21J14996 on the CD) is NI-FBUS Communication Manager only, and doesn't include NI-FBUS Configurator or Monitor. Please check with your purchasing department.
If you need to configure FF network online, you'll have to use NI-FBUS Configurator.
The product page is here
Message 17 of 17
(7,817 Views)
