FOUNDATION Fieldbus
I am having problems with NI-FBUS configurator hanging when I try to view the parameters by double clicking on the block
I am having problems with NI-FBUS configurator.  When I double click the function block to expand the block and view parameters the configurator will hang and eventual issue a "Fieldbus Configuration Application has Stopped Working" error.  I can use dialog and see each parameter with the "getobject" command just fine.  I have uninstalled the package and reinstalled it with no change.  I am operating Windows 7 with configurator version 4.1.0.49152  Comm manager ver 4.1 with the USB interface adaptor.
Any ideas would be appreciated.
(7,235 Views)
Hi
This might be a bug fixed in version 4.1.1, which is free for you since your version is 4.1.0.
Please try to upgrade it here
(7,220 Views)
