FOUNDATION Fieldbus
Menus
I am trying to create methods and use the NI Configurator 3.1.1 to display them.
I cannot seem to make any menus appear.
If I declare a Method, it appears under the NI 'Methods' menu, but I get an interpreter error.
When I run the method, I get this:
Method interpreter runtime error
Error: Line 4: Undeclared identifier "_l"
Method execution did not complete
Method execution has halted
Can you give me any ideas as to what I may be doing wrong?
Message 1 of 15
(11,332 Views)
This error is reported by DDS (Device Description Service). A simple way to verify it is to run this method in DD Super Viewer, it should have the same behavior. To solve this problem, please refer to the following documents from Fieldbus Foundation. They should be installed with the Tokenizer and they could help you in the details for sure.
--Device Description Implementer's Guide
--Method Development Guide
Please be aware that, if you use METHOD_ITEMS in the block's definition or use REDEFINE METHOD_ITEMS in the block's redefinition to refer some methods, NI-FBUS Configurator will use a "Method" menu to group all these methods. Another way is to show the method in the customized menu. The attached file shows an example.
If there is still problem, would you please send me the whole DDL file?
Hope it help and please feel free to let me know if I could do more help for you!
Josiane Zhou
Product Support Engineer for NI-FBUS
Message Edited by Josie on 10-18-2006 07:29 AM
Message 2 of 15
(11,323 Views)
I have attached the ddl source for the problem I initially mentioned.
The  MENU_ITEMS are under the block lx_xd_block.  The actual definitions of the menus and method are listed below.  They are from XDMethods.ddl which is a #include in the main ddl file.
/*************   Menus and Methods **
    **** maybe in separate file??? ******/
MENU    device_root_menu_xd
    LABEL   "|en|  Logix XD Wizard";
    ITEMS
       mn_status (REVIEW),
       mn_setup (REVIEW),
       read_final_value
MENU    mn_status
    LABEL "|en|Status ";
    ITEMS
        PARAM.FINAL_POSITION_VALUE.VALUE
MENU    mn_setup
    LABEL "|en|Setup ";
    ITEMS
        PARAM.VALVE_SN
METHOD read_final_value
 LABEL "Read Final Value.";
    CLASS   OUTPUT & SERVICE;
 DEFINITION
     long   status,lstat;
     unsigned long id;
     unsigned long index;
     float  fltval;
     id = ITEM_ID(PARAM.FINAL_POSITION_VALUE);
     index = MEMBER_ID(VALUE);
     status = get_float_value(id,index,&fltval);
     lstat = display_builtin_error(status);
I've also attached a couple screen shots of what I saw.
J.
Message 3 of 15
(11,310 Views)
I cannot tokenize the DevwithMethods.txt, so I create a simple DDL file (menu.DLL in the attachment) and put the menu and method items into it. I changed the definition of FINAL_POSITION_VALUE, because I cannot find the status_contained_nvr and float_contained_nvr. The menus work well as shown in the attached image file.
As to the method, please check the "status" value before you call display_builtin_error(). For example:
if (status != BLTIN_SUCCESS)
Hope it helps!
Josiane Zhou
帖子被fieldbus在10-20-2006 05:08 AM时编辑过了
Message 4 of 15
(11,293 Views)
Simulator Example:
I built the new DDs as outlined in the readme.
The only change was that I had to change the imported DD_REVISIONS, since I have standard library 2.0.  When I load it into the Offline Interface, I always get this error:
NIF_ERR_OFFLINE -- Offline NI-FBUS error (Error Code = -256).
Any suggestions?
I've attached my modified version of the ddl source.
J.
Message 5 of 15
(11,278 Views)
Sorry, I verified the previous DD with NI-FBUS 3.2 only. If we use previous version of NI-FBUS software, we need to do some changes. On the other hand, please be aware that NI-FBUS 3.1.1 supports DDS 4.2, while NI-FBUS 3.2 supports DDS 5.0.5. So please pay attention to both the NI-FBUS version and the tokenizer version.
Attached is the latest DD/CFF file which is verified with NI-FBUS 3.1.1.
For your information, evaluation software of NI-FBUS 3.2 could be found through the following link, which has better performance and better error tolerance. The offline operations are available within this version.
http://digital.ni.com/softlib.nsf/websearch/F8F368E7A6563319862571E600140826?opendocument&node=132060_US
Hope it helps!
Josiane Zhou
Message 6 of 15
(11,267 Views)
I'm trying to get my methods to work in NI Configurator v3.2 and I get an error when I use the get_acknowledgement() or display_message() builtins.  For example, the following method results in the following error when it's run.
METHOD reset_mass_total
    LABEL "Reset Mass Total v12" ;
    HELP  "This method resets mass total to 0";
    CLASS OUTPUT & DIAGNOSTIC ;
    DEFINITION
        unsigned long   id;
        long            status, status2;
        id = ITEM_ID(PARAM.RESET_MASS_TOTAL);
        status = put_unsigned_value(id,0,1);
        Abort_On_Builtin_Status_Error(status);
        status = send_value(id,0);
        get_acknowledgement("Mass Total has been reset to 0", 0, 0, 0);
Method interpreter runtime error.
Error: Line -1:
Method execution did not complete.
Method execution has halted.
If I comment out the get_acknowledgement() builtin, the method runs fine.  Do I have to do anything special to display messages?
Dawn
Message 7 of 15
(11,194 Views)
For what it's worth, I have found that builtins like display_message and get_acknowledgement seem to work if you declare both id and index as long and assing either or both to 0, when there is no actual id or index, then reference them when callin g the builtin.  I don't know why, but it worked on 3.1.1.  I don't have access to 3.2
Message 8 of 15
(11,189 Views)
I tried defining id and index and it didn't help.
    LABEL "Reset Mass Total v14" ;
    DEFINITION
        unsigned long   ids, indices;
        unsigned long   id;
        ids = 0;
        indices = 0;
        get_acknowledgement("Mass Total has been reset to 0", ids, indices, 0);
Message 9 of 15
(11,188 Views)
Both NI-FBUS Configurator 3.1.1 and 3.2 use the DDS (Device Description Service) of FF to interpret/execute the methods and then format/display the returned result. Version 3.1.1 uses DDS 4.2 while version 3.2 uses DDS 5.0.5, this might explain why "defining id and index" works in 3.1.1 but fails in 3.2.
I would like to suggest you ask FF for this issue. They could provide direct and detailed help for sure.
http://forums.fieldbus.org/
Hope it helps and please feel free to let me know if I could do more help for you!
Josiane Zhou
Message 10 of 15
(11,178 Views)
