FOUNDATION Fieldbus
Read function block parameter with its object dictionary index in VC?
How do I read  a function block parameter with its object dictionary index using NI-Fbus Communications Manager Programmer VC API?
(7,361 Views)
You can use  marco NIFB_INDEX(index) as parameter for nif_ReadObject function. The index is the relative index of the parameter in the block.
nifError_t nifReadObject(nifDesc_t ud, NIFB_INDEX(uint32 idx), void *buffer, uint8 *length)
Please also refer to 'NI-FBUS Hardware and Software User Manual' from Start->National Instruments->NI-FBUS->Manuals. Page 6-41 ~ Page 6-44 describe the detail information about nifReadObject() function.
Page 6-51 ~ Page 6-52 explain the usage of marcos for processing index.
Feilian (Vince) Shen
(7,358 Views)
Thanks for the feedback.
After read the manual you recommended, I think I can do the following to read a parameter with its OD index:
the relative index of the parameter in the block = the parameter OD index - the starting OD index of the block
Then use the marco NIFB_INDEX( parameterRelativeIndex ) with nif_ReadObject function to read the parameter
(7,351 Views)
