FOUNDATION Fieldbus
NI-FBUS Configurator 4.1.0.49152 + USB-8486: High delay between consecutive write actions
imagine a case where you have a (transducer) block with at least around 12 parameters all of which have both read and write access:
PARAMETER_1
PARAMETER_2
PARAMETER_3
PARAMETER_12
PARAMETER_13
When editing two of these parameters which do not "reside in close neighborhood" (like PARAMETER_1 and PARAMETER_12) and then writing them down via "Write Changes" in the block view I observe, that there is a high delay between the write access for the first and second parameter (up to several seconds).
Since I am device developer I can see this during device debugging.
Can this delay be avoided?
Regards
Mike
(8,123 Views)
Accepted by Mike_Al
Hi Mike,
1. Try to uncheck the "Period Update" box in the upper left conner of the Block view. It's possible that this caused a conflict with your read/write action.
2. Which kind of device are you using that you are having this issue with? Have you try it on other devices? Just in case the extra long delay was caused by the device.
(8,101 Views)
Hi Lewis,
I have switched of the periodic update and it seems that now there is no significant delay anymore.
Thanks for your help!
Regards
Mike
(8,096 Views)
