FOUNDATION Fieldbus
Reading viewlist objects using C# API
I am using the NIFBUS 4.1 C# API and i am trying to find a way to read the view lists of a block--e.g.
VIEW_1, VIEW_2 etc. However i am getting the following exception
System.NullReferenceException was caught
  Message=Object reference not set to an instance of an object.
  Source=NationalInstruments.Fieldbus
  StackTrace:
       at NationalInstruments.FieldBus.ParameterHandler.VarListParameter..ctor(nifObjTypeList_t TypeData)
       at NationalInstruments.FieldBus.ParameterHandler.Parameter.CreateInstance(nifObjTypeList_t TypeData)
       at NationalInstruments.FieldBus.Block.ReadParameterByName(String name)
       at Metran.CT.Dut.GetParameter(Block block, String paramName, Boolean Critical) in C:\MyFolder
       at ReadViewList(Block block, string paramName)
 InnerException:
This exception is thrown when i do
block.ReadParameterByName("VIEW_1")
Any help will be appreciated!
(7,873 Views)
Dear,
I confirmed your problem with the development team. It is a bug when doing the variable list reading. I am sorry for that. You can contact with fieldbus.support@ni.com
We will help you to resolve it.
Best regards.
(7,864 Views)
