FOUNDATION Fieldbus
Duplication of device tags error
In my application, I need to connect a few devices one at a time to the link. These devices share the same device ID, device Tag and node address. But these are connected to the link one at a time (others are switched off). I am seeing an error "Duplication of device tags" in the NI Fbus configurator and i am not able to communicate with the devices.
I will be able to communicate with the device if I close the NI FBus communications manager and reopen it. Please let me know if there is any method to communicate with the device with out resetting the communications manager.
Sundar
(7,279 Views)
I am sorry your request is not supported in the previous releases. We never assume some devices share the same device ID at all. You can send your request to fieldbus.support@ni.com. We will consider whether to add this new feature. Currently, as far as I know, this is no approach to
do it.
(7,267 Views)
