FOUNDATION Fieldbus
What constitutes an E_COMM_ERROR on NI Fieldbus?
I have a test station with NI Communications Manager and Configurator version 2.3 and my application installed. My application does a lot of reading and writing into blocks and their parameters and very often my application would drop an E_COMM_ERROR while writing, using the function fb_write_unsigned8 as an example. This error is intermittent and it may not reappear with the same fieldbus device, same application, writing function and parameter. I appreciate it if somebody would tell me what constitutes an E_COMM_ERROR and what forms it's intermittentness.
(7,244 Views)
Usually the error E_COMM_ERROR is caused by abnormal communications in fieldbus network, especially when the fieldbus traffic is heavy. So you might need to adjust some network parameters to avoid communication failure.
You can contact "fieldbus.support@ni.com" for further support and help.
(7,244 Views)
