Feedback on NI Community
A few recent forum updates
Alan's screen shots show the same thing I was seeing.  Have used the forum several times today without
any problems, always properly formatted.
Matt
Message 11 of 18
(7,264 Views)
Mine was fine for a while, now it is again screwed up.
Alan
Message 12 of 18
(7,254 Views)
Hi Alan,
Looks like you're getting the same thing I was.
Out of curiosity, are you running a script blocker or an ad blocker?
I can't tell for sure if they could be part of the problem or not, as I've seen that same problem whether I had the add-ons enabled or not.
Patrick Allen: FunctionalityUnlimited.ca
Message 13 of 18
(7,226 Views)
What does the rest of the ni.com site look like when you see that happen?  I wonder if you are experiencing very slow loading times.  I notice that the header doesn't look right and when that happens, it is usually due to overall site slow downs.
Laura
Message 14 of 18
(7,223 Views)
The entire forum looks just as out of sequence as the screen shots, I can go to the messages and read them, although they are difficult to read in that format. I see no slow down at all. I have been on and off the LabVIEW forum all day today and it has not happened once, everything is fine today. But it has been hit and miss for about 2 weeks now. I think it started to get wacky  right after the LabVIEW forum was down for maintenance recently.
I am using Firefox in its default configuration.
Alan
Message 15 of 18
(7,214 Views)
Oh, I missed your point. The rest of NI.COM looks normal, it is just the forums that are messed up. And they are not slow to respond, just messed up format.
Alan
Message 16 of 18
(7,211 Views)
Every thing has been fine for the last 3 days, did something change?
Alan
Message 17 of 18
(7,180 Views)
Erk!
Everything was fine.  But all the formating is once again lost for me.  Firefox just recently updated to 3.6.13  So it's possible that could be the culprit.
Message 18 of 18
(7,125 Views)
