Feedback on NI Community
Announcing the NI Discussion Forums Upgrade
@smercurio_fc wrote:
@Laura F. wrote:
  • Ray R - do you have font set in the browser somehow?  I also use that version of firefox and that text size setting and can see board names as bold when there are unread messages.  The font in your screenshot definitely looks different from what I see.  Also, what is your monitor resolution?  I'm not certain what you mean about the HTML tags, you can still edit your message in HTML form so I think I'm missing something.  I think your unexpected error was due to a bad link in a message that has since been corrected. I have not noticed the cursor disappearing.  Let me know if you notice something that causes it to happen.
I have found an instance when the cursor disappears: Resize the editor.
I tried resizing the editor and it didn't work 😞
Happened for the 2nd time today.
Message 131 of 273
(5,868 Views)
Hi Laura,
one more complaint/idea/suggestion:
I think the email notification for new messages is way to big in terms of screen size...
See that pic:
17363iFB28F2541024C312
That's what I see when opening those emails.
- Well, I don't need the NI logo on top, I already know it's from NI because of the subject line...
- I don't need my name in bigger font and bold, I know it's an email for me when it reaches my mailbox...
- The email top part consist of a lot of redundant information, as marked.
- the mail body is centered and only uses ~640 pixels width. It even has to wrap some text due to using a bigger and bold font... Why don't you stick with left aligned text, using the full width with no word wrapping?
When receiving those emails all I need is an indication of the thread (which is already done in the email subject) and one link to the latest reply. As I usually use the preview pane (of Thunderbird) I even have to scroll to click the link. Could you please revise the email formatting to something more compact? Like holding the relevant information in the first 4 lines of the email body?
Message 132 of 273
(5,863 Views)
GerdW, I will second your opinion and add one more:
1. The Subject is too long. When viewing my GMail on a netbook (read, 1024px horizontal resolution) I cannot see any of the good stuff, all I see is "NI Discussion Forums Subscription: 1 Update ..." (you can see how long the subject is in the image below, although the screenshot was taken on a 1920px horiz monitor so I'm able to see a little of the subject. Imagine seeing less of the subject and none of the body if I'm on the netbook)
2. See additional issue below:
17365i26119445B23B7EB4
Message 133 of 273
(5,860 Views)
What didn't work? Having the cursor disappear when you resize the editor? Happens to me each time. And clicking in the editor doesn't bring it back. Using Firefox 3.6.4.
Message 134 of 273
(5,842 Views)
Hi Everyone - My latest responses are below:
  • smercurio - that's the same macro I tested in both Firefox and IE and I used rich text both times. I notice a second quotation mark is missing from the second URL.  Perhaps try adding that back?  I've noticed that the new version is touchier about HTML when I'm changing the announcements.  Thanks for the tip on the disappearing cursor, I've reproduced and will report.
  • Roberto - Do you have my email address?  You could just send them to me directly.
  • muks - In case an image is inappropriate it can be reviewed by a moderator.  We don't use that feature.
  • GerdW - the email header was added quite a while ago after a request by the communications team.  The format of the email I think is meant to be flexible to handle both board and thread / topic subscriptions which sometimes results in duplicate links.  I will submit your suggestion to make the format more compact
  • Jack - the subject of the email has the number of updates because there can be multiple updates if you have a daily digest setup. I also see the Rif problem in my own email and will report it.
Some fixes and changes should be made tonight. I'll list them tomorrow after I verify the changes.
Laura
Message 135 of 273
(5,843 Views)
We have a slightly different scenario.  My cursor does not dissappear.  It is not there in the first place.
Occasionally (twice so far), I simply click replay and without any other intervention, there is no cursor.
Message 136 of 273
(5,850 Views)
You see how different we are!
I didn't even open the update emails! (I think I have not opened any of them in the past years Smiley Happy ) I use Magic Mail Monitor to see my mailboxes content and looking at the message subject I already know which discussion to open. Next I directly delete the message as I don't need to open it.
I don't mind the link to go directly to the last reply: I could have more replies unread and simply opening the discussion automatically lead me to the first unread message, so...
Message 137 of 273
(5,846 Views)
I seem to remember I have: I will check tomorrow when coming back to my office.
Message 138 of 273
(5,844 Views)
Laura
Yup, that was it. Missing quote. Sometimes a third eye is required to catch those little things. Thanks... Smiley Wink
Message 139 of 273
(5,838 Views)
But there is already a "Report to moderator" right?
Message 140 of 273
(5,811 Views)
