Feedback on NI Community
Attachment formats
Hello Molly,
Would it be possible to add .rft format to the list of allowed attachments. I try not to documents in application specific formats so those without that application can read them, and sometimes a plain text file is hard to format for easy reading. So I like to use .rtf files so I can at least have some simple formatting.
Ed
Ed Dickens - Certified LabVIEW Architect - DISTek Integration, Inc. - NI Certified Alliance Partner
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
Message 1 of 12
(6,170 Views)
Ed -
The rtf file extension is now accepted.
Have a good one!
Molly K.
Web Support & Operations Manager
Message 2 of 12
(6,163 Views)
Talk about service Smiley Wink
Thanks Molly
Message 3 of 12
(6,171 Views)
And could you block the attachment of bmp filesSmiley Wink? I'm to the point that I won't even open one anymore.
Message 4 of 12
(6,163 Views)
Dennis -
I can block them.  I have had this request once in the past.  What is the general consensus?  No bmps?  I need two more votes for it (and none opposed), and I will happily do it.
Thanks!
Molly K.
Message 5 of 12
(6,164 Views)
The problem with BMPs is size and I am also voting for disallowing them as attachments. It does not seem reasonable to have a simple FP screenshot with a file size of 4MB.
OTOH, the people that can barely get a screenshot in any format are the ones also most likely needing help with LabVIEW. 😉
If we disallow BMPs, there should be a clear help section on how to make and attach a screenshot of a front panel  and block diagram.
Some of us even posted VIs that allow to create a PNG of the FP and BD of any VI. (See for example this post).
Message 6 of 12
(6,154 Views)
Molly,
I'll second that
Ray
Regards
Ray Farmer
Message 7 of 12
(6,153 Views)
I agree.
Message 8 of 12
(6,145 Views)
me too
Chilly Charly    (aka CC)
Message 9 of 12
(6,130 Views)
Molly, I say NO BMPs. However, in addition to the help, there should be, if possible, a piece of text that says (if people try to upload one) "you can't post BMPS, but... (you can use JPG or PNG or GIF and to create them you should...)".
___________________
Try to take over the world!
Message 10 of 12
(6,030 Views)
