Feedback on NI Community
Search Box - Movin' on up!
Did you notice that the search box jumped to the top of all the pages?  What do you think?
Have a great day!
Molly K.
Web Support & Operations Manager
Message 1 of 11
(6,549 Views)
At first I noticed something looks weird, then I realized that's what it was.
In general, I think that's a better position than at the bottom, although now I will have to get used to it again. Is it possible to have it in both places? I think that would be the best thing.
___________________
Try to take over the world!
Message 2 of 11
(6,553 Views)
Hi Molly,
While we are rearranging things related to "search", I propose the following modification for the advanced search page:
  • After I do an advanced search, the list if search results should be placed above the search dialogs!
Reason:
In the current placement, all search results show up below the search dialogs, outside the main window margin on typical monitor resolutions and we need to scroll to see them. If there are multiple pages of results, each click on "next page" or "previous page" again makes all search results disappear mostly below the lower window margin, while the screen is nicely focused in the search terms again (Something we have already seen!). To browse through multiple pages of results, it is always a "next...scroll down...next...scroll down". Tedious!
If the search results are placed above the search dialogs controls, we can browse through multiple results pages easily by "next...next...next...previous..." etc. All the new, interesting stuff is directly in view.
Message 3 of 11
(6,548 Views)
Great feedback tst and altenbach!
I will add those requests to the list.
Thanks!
Molly K.
Message 4 of 11
(6,536 Views)
Hi Molly,
Is it possible to search / view the author's questions only?  What I mean is that when searching a topic, you can filter for title or description of the question and not the answers..
I was looking for an old post which I was the originator ( posting a question ).  Since then, I've answered many (which I found), but could not find my own question.
Ray
Message Edited by JoeLabView on 10-21-2005 10:19 AM
Message 5 of 11
(6,507 Views)
Joe LabVIEW -
There isn't a clean way to find all the questions you have asked (yet).  It is a feature we have planned for the future.  I did some digging and found some of the questions you have posted, but probably an alteration of CC's List VI would get the data more easily.
3.3V Digital I/O / Digital I/O
Concurrent applications using System Exec.vi do not run concurrently when executed within TestStand / LabVIEW
More details on "Concurrent applications using System Exec.vi do not run concurrently when executed within TestStand" / LabVIEW
Can I use the PCI-GPIB as a DAQ card to obtain data from a Spectrum Analyzer? / LabVIEW
Concurrent applications using System Exec.vi do not run concurrently when executed within TestStand / TestStand
Good Morning NI - I'm here.. / BreakPoint
Has anyone written LabWindows/CVI or LabView vi for the EST/VisionProbe? / LabWindows/CVI
How do I pass a void *pointer to a dll in LabView / LabVIEW
How does TestStand 3.0 create a sequence adapter for LabView? / TestStand
You might ask what to do with this information now...  Well, my recommendation would be to take some keywords from the subject and do an advanced message search for posts where you were the author, in the specified board, and over any time range.  I know I didn't get all of the questions you asked, but I'm hoping it was one of these 🙂  If not, I can go try to find the others.
Have a great weekend!
Molly K.
Message 6 of 11
(6,494 Views)
Thanks Molly,
Unfortunately the one I was looking for is not in the list.  But that is okay, since someone else provided the details to a posting.
I am curious, how did you do that?  Did you modify CC's List VI?  I might actually have a look at it.
Ray
Message 7 of 11
(6,492 Views)
Joe LabVIEW -
To be honest, it wasn't pretty.  Brace yourself.  It involved doing a search for all messages posted by you, changing the number of replies posted on the page, highlighting the results, pasting them into Excel as text and sorting them.  I warned you...
I guarantee CC would have a better solution 🙂
Thanks!
Molly K.
Message 8 of 11
(6,484 Views)
JLV, one "way" would be to open the advanced search page (here is an example of a time where I would have liked it to be on the bottom of the page), search all the forums, with no time limit and search the message subject only for any (the second field) of a list of common likely words (For example, I used "a an are labview is it can has as I do you me",  but you can (and should) add some more).
Then, the key to finding the questions is to add "re:" to the third field (the one called "without the words"). This will drop almost all of your replies, because the default message subject for a reply is "re: whatever the original line was". It's not foolproof, but it should detect at least some of your questions. I found 6 for you, but with more words, you should fare better, especially if you remember specific words from the title.
___________________
Message 9 of 11
(6,473 Views)
Here are your 15 threads.
Getting to know more about ...
Adding a "FAQ" section to the LabView forum
Ben breaks 3000 -- Congratulations
Is it possible to step into a CVI dll when called by TestStand?
How much loading does SetComTime timeout impose on the CPU?
Good Morning NI - I'm here.. BreakPoint
Concurrent applications using System Exec.vi do not run concurrently when executed within TestStand (2 posts in different forums)
3.3V Digital I/O
Using VI to run Macraigor BDM programmer
Chilly Charly    (aka CC)
Message 10 of 11
(6,470 Views)
