Feedback on NI Community
Diadem scripts
I''m trying with little experience, to write a script or scripts to take multiple Excel worksheets of data which includes the data I want. I need portions of the channel data for voltage and discharge capacity so I think my approach should be to concatenate the worksheets in DIAdem and take only the voltage, the cycle_index, and the discharge capacity. I would then like to select only the 1st, 25th, 50th, 75th..And 300th cycles and plot out only the data which occurs in those cycles. With NI's help I've gotten through concatention of the voltage, discharge capacity, and cycle index. I now need to isolate only the data needed to plot and plot it. Can anyone help?
Bustersboy
(5,916 Views)
You posted in the wrong forum. Try here instead.
(5,915 Views)
How do I know which forum I'm in and then how do I get to that forum?
Bustersboy
(5,905 Views)
You start at the top   http://forums.ni.com/
Plus there is the title of the forum near the top of the page, and there is a breadcrumb trail below that.
(5,901 Views)
