Feedback on NI Community
nxt loops with touch sensor
Hi I'm looking for some help. I want the touch sensor when pressed to run a loop that causes 1 motor of the nxt to run moving a certain distance at a certain power and then stop. Then I want it to run again when the sensor is pressed (running the same loop) but only running on the press of the sensor  when the sensors pressed. I have tried using a case structure and by putting the same circuit I the true and false case I thought it might work but it doesn't and it wasn't a very practical solution
Can you help??
Ailish
(5,532 Views)
You need to post this question here. This fourm is not for these type of questions:
http://forums.ni.com/t5/LabVIEW/bd-p/170
Tim
GHSP
(5,531 Views)
