Feedback on NI Community
Dysfunctional album
Once we posted a lot of images, the album here becomes quite dysfunctional.
  • There is no option so change the sort order and they are sorted oldest first. In a typical scenario, I am probably more interested in the more recent images. These should be on top.
  • There should be a way to pick the sort order (oldest or newest first).
  • If I delete an image from the bottom of a large page, I get a confirmation dialog, but after I OK it, the page scrolls all the way to the top instead of approximately staying where it was.
  • There is no way to identify and cleanup images that have not been used in posts. Sometimes, when composing, I insert an image, notice a problem and insert a newer version if the image (repeat...repeat...), all while editing, i.e. before submitting the post. At the end, all pictures trials end up in my album. I think that images inserted while editing should not go into the album unless I actually post.
(2,686 Views)
The solution here is simple: Don't use albums.  Just attach the image to your post and then edit to add those images to the message.  I just wish we didn't have to edit the post in order to display the attached images.
GCentral
(2,634 Views)
Hi altenbach,
Thank you for the suggestion. I have added this request to our development backlog. We will address it when availability and priority allows.
Best Regards,
Kristi Martinez
NI Community Support
(2,619 Views)
