Feedback on NI Community
Error in looking who gave kudos to a post
Forgive me if somebody already posted it: I found no meaningful search criteria to find that post...
Several times it has happened to me to look who gave kudos to some post: normally I arrive at the correct user list, but sometimes I ended up giving a kudo to that post, insted. After I noted this, I took the habit of hovering with the mouse on kudos kount, wait for the balloon "Click here to see who gave kudos" and then click: even in this case it has happened to me that I ended up giving a kudo! Smiley Surprised
It's happening both on Firefox 3 (don't remember the subversion) and on IE 8.0 on 2 different machines, both on WinXP SP3.
(6,443 Views)
Accepted by RobertoBozzolo
The message options (top right) has a "revoke Kudos" option that will let you fix your mistake err the forums mistake.
Ben
(6,418 Views)
Thanks Ben: I never really looked at the message options menu.
It works exactly as you said and it's not subject to time limitations (i.e. I can revoke my kudos even some days after I gave it).
(It will be better that this inconvenience doesn't happen, though. But at least it can be corrected)
Message Edited by Roberto Bozzolo on 04-12-2010 03:12 PM
(6,411 Views)
Now this was worth reading - I have had this problem too and got frustrated a few times by Kudoing "bad posts" when I was trying to see who was crazy enough to have done so already.
James
Kudos to you both for a good question and an enlightening answer
CLD; LabVIEW since 8.0, Currently have LabVIEW 2015 SP1, 2018SP1 & 2020 installed
(6,277 Views)
