Feedback on NI Community
Error when accessing service request page
I'm trying to a raise service request, but the links below just return page errors. Does anyone else have this problem?
Certified LabVIEW Architect
Unless otherwise stated, all code snippets and examples provided
by me are "as is", and are free to use and modify without attribution.
Message 1 of 10
(8,814 Views)
Hi MichaelBalzer,
I have tested in all three browsers and did not have any issues. Are you still seeing the error page?
Best Regards,
Kristi Martinez
NI Community Support
Best Regards,
Kristi Martinez
Message 2 of 10
(8,769 Views)
There is clearly still a problem just now. The top link gave me the same error as shown. Then I tried the second link, which worked. Then I tried the first link again and it worked too.
(There might be a race condition between servers where it might take a while to determine correct location and pull up older service requests. Just guessing.)
Message 3 of 10
(8,762 Views)
@altenbach and @MichaelBalzer
Thanks for the feedback. After looking into this further we have been able to reproduce the behavior on some browsers. To confirm it's the same problem can you all let us know what browser and version you are using?
We have also seen the issue resolved by simply refreshing the page. While this isn't a long-term solution it may work in the interim until we can resolve this issue. Can you try refreshing the page to see if it loads correctly?
Carli S.
Troubleshooting & Maintenance Digital Business Manager - NI
Message 4 of 10
(8,755 Views)
Chrome
Message 5 of 10
(8,748 Views)
Firefox
I experienced this on Firefox 75.0 64-bit (Windows 10, build 1909)
Refreshing seemed to work.
Certified LabVIEW Developer
Message 6 of 10
(8,734 Views)
More (possibly related?) symptoms:
Message 7 of 10
(8,730 Views)
I'm using Chrome 81.0.4044.138 (Official Build) (64-bit). Refreshing doesn't help.
I have been able to access the new support request page after logging in using an incognito window, but there's now a problem that I can not see past SRs.
I also see the redirect behaviour JKSH is seeing.
Message 8 of 10
(8,727 Views)
On the bright side, my request was not lost. I've just received an email response from a Technical Support Engineer; thanks!
Message 9 of 10
(8,697 Views)
Looks like this is working on my end now, though I still can not see past SRs.
Message 10 of 10
(8,594 Views)
