Feedback on NI Community
Forum Update
Molly, here's some more of the floated boards saga - I floated the braimstorming board (which still doesn't appear in the board list, BTW) and for some reason it keeps changing its position between being the second item and the fifth item on the floated list. Over the last 3 weeks I think this must have happened at least 4 or 5 times. Any idea?
___________________
Try to take over the world!
Message 51 of 54
(2,009 Views)
Also, I'm glad to see you blocked BMP posting, but unfortunately some people seem to be able to outsmart (?) that.
___________________
Message 52 of 54
(2,008 Views)
And while I'm at it, it's very good that the default search time frame was changed to "any time" rather than "last 90 days", but I see that now you removed the time limit option, which could be a problem. When searching for something which is too common it's much easier to set a time frame than to sort by time and then start going through the results. In my opinion, the best option would be the ability to set a time window (start date and end date) for the search.
___________________
Message 53 of 54
(1,969 Views)
tst -
Exactly.  What they want to implement in the future is a start and stop time for the searches.
What you can do in the meantime is run your search and then you can sort the results by date (it will sort all of them now instead of just the past 90 days).  That way you can see the latest ones first or dig around in the desired timeframe.
Thanks!
Molly K.
Web Support & Operations Manager
Message 54 of 54
(1,939 Views)
