Feedback on NI Community
IE 8 running on XP with Skype while sitting in Ben Tracker eqauls memory leak !?!
I have been in the habit of leaving a web-page onpen on the Ben Traker page to watch for replies for a couple of years now.
About tow weeks ago I had to add Skype.
Ever since then the IE window has been gobbling up memory such that when I come back to the machine after an hour or so, there is alomost a Gig of memory allocated to the IE window. I close the window an my memory frees up fine.
Q's
Anyone else see this behaviour?
Anyone know what SAkype could be doing to me and how to stop it?
Curious,
Ben
(6,026 Views)
Doh!
I just shut-down Skype (I think) to see if that stops it.
Ben
(6,025 Views)
Do you get the same problem using a different browser?
regards
Ray
Regards
Ray Farmer
(6,017 Views)
If I had to guess, I'd guess that Skype loaded a plugin into IE. You should check the list of add-ons for IE to see if this is the case, and you can disable/remove the plugin.
(6,015 Views)
