Feedback on NI Community
Ignore my two posts below! My finger slipped & before I knew it I had posted twice! Anyone know how to delete?
Bob,
easiest would be to go to the post and click on "options" in the upper right corner of it. There you can select "Report to a moderator". Do it and you'll get a small form where you can express your concerns, e.g. Write that it is a duplicate post and should be deleted. 🙂
Do this for the mentioned two posts, and even for this thread, which is no longer meaningful once the other posts have disappeared 😉
WIthin 5 minutes of your post, you can also edit your own post (via the options link), so if you're fast enough, you could replace the text with a link to the real post.
In any case, you should reply in the obsolete thread to point users to the real thread (as I have just done). This will prevent answers in the wrong place.
(3,819 Views)
