Feedback on NI Community
Voltage measurement using PCI-MIO-16E4 and CB-68LP
I want to measure voltage from a single phase power supply panel using PCI-MIO-16E4 DAQ card and I am using LabView 7.1, DAQMx s/wres. I am using the transducer VT7-010D for scaling of input, as our DAQ cannot take high voltages. I am not sure if I can use this transducer as it says input 0-600V Dc and output 0-10V Dc, but I am using it and applying AC voltage from 0-100V.
Connection is from Power Panel to transducer and then from transducer to CB-68LP and from there to DAQ card inside PC. I use multimeter and it says right at i/p side and o/p shows for 10V i/p ac = 0.1V o/p dc initially and from 50V i/p shows 0.6Vdc and continues increasing. But Labview shows 0.1V = 0.5V (p-p) instead. I would like to seek help from experts in measuring this simple task. I am using inbuilt VI to do this task.
Thanks and appreciate any help
(3,911 Views)
I think your post belongs in the Multifunction DAQ Forum . This board here is for feedback on the forum, not for technical issues. Good luck! 🙂
(3,904 Views)
