Feedback on NI Community
multiple PID blocks
I'm trying to use two PID blocks in a VI to implement two cascaded PI controllers.
When I set the gains in one of the blocks it also changes the gains of the other block. I can't use two PIDs even if I make two SAVE AS of the original block for the different PIs!
Is there any solution for this?
Thank you,
João
(4,267 Views)
You stumbled into the Forum feedback board by mistake.
What is a "PID block"? Depending on the answer, your post belongs into the LabVIEW board: http://forums.ni.com/ni/board?board.id=170 or one of the hardware boards.
(4,258 Views)
And while you're posting your question, it would be good if you post your code as well (File>>Save with Options>>Development Distribution). It would make it much easier.
As a shot at guessing the answer - the PID VIs supplied with the control toolkit are reentrant - they can be used multiple times in parallel to achieve different results. If you wrote a VI that wraps them, you should make it reentrant as well. Go to File>>VI Properties>>Execution and check Reentrant Execution. This will mean each time you place the VI on the diagram a new copy will be "created in memory", so they can have different data. Read the help on this for some more details.
___________________
Try to take over the world!
(4,254 Views)
Hi!
I'm sorry for posting in the wrong forum.
Attached I send my VI. Even with the reentranted option checked the problems remains.
Thanks for the help!
(4,249 Views)
