06-16-2016 08:22 PM
I miss being able to navagate to the 20-40th posts.
Nope, the next page button is gone
Looks like some basic elements got forgotten on the profile pages
06-16-2016 08:24 PM
That's odd. I'll have to follow up with Lithium Support about this.
06-17-2016 08:26 AM
I do see the pages links on my Latests Posts page. It only goes up to page 8. (Which not being able to see all posts is a problem that was reported awhile ago.)
06-17-2016 08:36 AM
Now, I see that my page numbers are back too -- going all the way to my first post (15 pages).
For RavensFan, I see 600 pages of posts:
http://forums.ni.com/t5/forums/recentpostspage/post-type/message/user-id/63946
06-17-2016 10:20 AM
@LiliMcDonald wrote:That's odd. I'll have to follow up with Lithium Support about this.
I got those pages back all the way to pg 485 Not sure what happened.
06-17-2016 01:15 PM
Yes. I can see back to page 600 also. That takes me back to about March 2010. (My first posts were around April or May of 2006).
06-18-2016 12:38 AM
Now. the Accepted Solutuons is AFU?
No navagation thingies again. I might have more than two "Marked Solutions." 🙂 at least y'all are upgrading! KUDOS!
06-18-2016 01:10 PM
Something is definitely weird. I opened the first page of my tracker to see if anyone replied to a thread I participated in recently and scrolled down to the bottom. An unusual thread icon drew my attention, so I looked at that line and saw that the date was from January. If you look at the marked dates, you can see that for some reason this page shows replies from April and then Februrary and January, while my post rate is high enough that is should only go back a few weeks at most (and I certainly had other posts between Feb and April). I haven't seen any sorting options, so I'm assuming this should be sorted by post time, as it always used to be.
But I do at least have the page navigation links
06-18-2016 09:53 PM
@tst wrote:Something is definitely weird. I opened the first page of my tracker...
And now it's back to normal and shows posts from last ~10 days as it should.
06-20-2016 07:55 AM
Lithium Support was working on this issue over the last few days, and stated this is why things appeared normal sometimes and other times not.
As of this morning, they stated this issue should be resolved. Things appear okay on my end. If you do see something wrong, can you also provide a link to the page you were on?
Thanks!
