Feedback on NI Community
firefox...
sorry to disturb again, but this page, for example, really doesn't work in the latest Firefox browser version 47: http://sine.ni.com/nips/cds/view/p/lang/de/nid/2881  It does work using IE 11.
Message 1 of 14
(5,081 Views)
I've got FF 47.0  That page comes up okay on my screen.
Message 2 of 14
(5,074 Views)
OK, good for you Smiley Wink  Any suggestions from your side what might cause this problem? I do not have any special settings (to my knowledge), am running Win 7 64 bit, English version, but am redirected to the German site: could it be that the German web version makes the difference?
Thanks!
Message 3 of 14
(5,071 Views)
Well.  I figured that knowing someone else was not having the problem is useful information also.  Smiley Wink
My first thought would be the German website, because that is the only obvious difference between your screen shot and mine.
I just saw how I could change my screen to show it in German instead of English.  But it looks okay there to me, so that must not be it.
My next suggestion would be do some of the things that might clear the cache.  Maybe something is wrong with the CSS sheet.  I can't tell you exactly how to that because I just never mess with those things.  My terminology may be wrong.
Message 4 of 14
(5,058 Views)
I also cannot reproduce this issue in Firefox 47.0 on Windows 7 Enterprise when changing my locale to Deutschland.
Can you check which language your Firefox is set to? Go to Options > Content > Languages > Choose.
Message 5 of 14
(5,052 Views)
Hi and thanks for your efforts!
Surely it is useful to know that it is working for others Smiley Happy
I also have verified to have the same language settings as Lili, so...
but then I found out that visiting the web site without being logged into the forums the web site displays correctly. Only after I log in I get the same blue rectangle, also at my home computer.
So what is the difference between being logged in or not?
Message 6 of 14
(5,044 Views)
Maybe it is just a bug in firefox, especially since it worked in previous versions (I assume).
Have you contacted them?
Message 7 of 14
(5,037 Views)
This could also be a bug in Firefox, of course. But actually I can't tell if it was working in earlier versions since I visit this Vision page only rarely.
No, I did not contact them yet.
Message 8 of 14
(5,030 Views)
That's seems even odder.  In my case, I was logged in.  And I just logged out and it still showed correctly.    (Not that this info helps you that much more.)
Can you try on a different PC logged in and not?
Do you know anyone else who has an NI account and can log into your PC and see if they have an issue.
Message 9 of 14
(5,024 Views)
Thank you again Smiley Happy
I agree that it is odd, what can I do... What I did was trying this web site at two different computers as said before, at work and at home. In both cases I observe the same scenario, however, also with the same configuration of OS and browser.
Never mind, if it is my specific situation I can deal with it using IE, I just wanted to report it in case others are affected as well.
Message 10 of 14
(5,013 Views)
