Feedback on NI Community
My Avatar
@LiliMcDonald wrote:
Jeff -- it wasn't our intent or Lithium's to change anyone's avatar. There is a bug in the platform that is causing these odd issues with everyone's avatars -- whether uploaded or chosen from the images provided here. It was unexpected for us too, and we are pressing on our platform provider for a resolution as quickly as possible.
Lili,  I'm NOT saying that NI OR Li are unresponsive.  I'm Just trying to keep the pressure on!  Admittedly, my avatar has suffered the worst of the effects from the recent Forum Upgrade.  It's a one case in multiple thousands bug!
Yet, it IS getting noticed negatively!   If i need to go back to a stock avatar- OK, but, I will not be a visible as the "Spinning 8-Ball" that community members have come to expect when I post.
Summary: I would wish that this bug never happened. Alternately, Roll back the "Fix" that included the bug or, code around the bug for this case. Yeah, code-arounds are never "right" but, sometimes expedient!
And while we are being blunt-
Yes, my avatar got hit bad, the "Bug" in the platform hit 5 out of the top 10 posters on the forums!
Message 11 of 32
(3,162 Views)
Yes, my avatar was handmade with every pixel carefully chosen, including color palette and frame timing.
So hands-off lithium! 🙂
Message 12 of 32
(3,157 Views)
Jeff·Þ·Bohrer wrote: Summary: I would wish that this bug never happened. Alternately, Roll back the "Fix" that included the bug or, code around the bug for this case. Yeah, code-arounds are never "right" but, sometimes expedient!
Yes, a rollback is something we are considering if there is not a decent workaround or if there is not a sufficient ETA for getting this fixed. We would need to consider the other bugs that were fixed / new features in the latest platform release, as well as coordinate with Lithium on the rollback. I'll definitely post updates as they become available.
Message 13 of 32
(3,155 Views)
I' m getting very close to contacting Greg Freeman to see if he still has the old source for the "for_Im_Stuck" Avatar and posting that for adoption by anyone that reads "Breakpoint".
I do not like being "disruptive" without a clear objective.  The flashing avatar is disruptive
But, then again, that is not a space in my Alias!
Message 14 of 32
(3,149 Views)
Unfortunately, I still do not have an update from Lithium on a fix for this issue. I've extensively attempted to find a workaround for the glitchy gif avatar, but to no avail. For now, I recommend you use an avatar that does not have the flash. The spinning 8-ball with no sparkle appears to work okay on the forums as an avatar. I know this is not ideal for you, but it is the best suggestion I have for now.
I'll update again when I have more.
Message 15 of 32
(3,110 Views)
If he leaves the current avatar up, the site needs a warning about PSE. 😄
Message 16 of 32
(3,104 Views)
So here's the issue: The Lithium image encoder fails to encode certain frames of gifs -- turning them into glitches. If you remove those frames the animation suffers but you prevent the glitches.
If you want a sparkle in your avatar, this gif has it, but is missing some frames.
Issue still not fixed, and this workaround isn't perfect, but it's what I've got for now.
Message 17 of 32
(3,094 Views)
It also looks better since it looks like it is still moving during the sparkle.
GCentral
Message 18 of 32
(3,089 Views)
Not the worst work-around.
It is recognazable and not disruptive.
My "Goal for the day" was find a gif editor and fix that darned flash!  Thank you for the support!  Now, If I could have that space back in my alias?  OK, i'm teasing!
For others. How does the avatar look on multiple browsers etc...?  Chrome, full and mobile sites are looking good to me.
Message 19 of 32
(3,077 Views)
It looks OK (maybe not great but much better than the flash) on Safari on the Mac.
Lynn
Message 20 of 32
(3,066 Views)
